Tesys T_External load current transformer and External ground current transformer
  • Industrial Automation
  • Solutions for Motor Management
  • Tesys T_External load current transformer and External ground current transformer
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys T
Back to Solutions for Motor Management
Khuong
Khuong
Cadet
Posted: ‎2025-05-05 12:48 AM
654
Dear all,
I have a project that shall use Tesys T motor management inside the MCC panel.
The problem is that we need to reuse the switchboard's existing MCT and ZCT. So I wonder if the Tesys T device supports MCT and ZCT of 1A or 5A secondary type or another standard?
1. According to the documents I have: Tesys T supports Load current transformer of 1A and 5A type. But I can't find the setting parameters for 1A or 5A secondary.
2. The documents actually don't mention that Tesys T supports 1A or 5A secondary ZCT.
I hope anyone can help me answer.
Thanks and Best Regards
  • Products
NeiB
Lt. Commander NeiB Lt. Commander
Lt. Commander
Posted: ‎2025-05-06 05:06 AM
Hi @Khuong ,
Trust this finds you well.
The configuration of current transformer can be done via SoMove (with TeSys T DTM) or from the HMI LTMCU (METERING SETTINGS):
Best Regards,
Neide
