How to ensure you make the right design for motor application in industrial system?
  • Industrial Automation
  • Solutions for Motor Management
  • How to ensure you make the right design for motor application in industrial system?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
ComPact NSX
VarSet LV
PowerLogic
PowerLogic P2
field url
PowerLogic
PowerLogic P3
field url
PowerLogic
Easergy Sepam Series 80
field url
Set Series
Motorpact
field url
TeSys T
field url
PowerLogic
AccuSine PCS+
field url
Altivar Process (Low Voltage)
field url
Altivar Process (Medium Voltage)
field url
Altivar Softstarter
Load more
Back to Solutions for Motor Management
Delcho_Penkov
Lieutenant JG Delcho_Penkov Lieutenant JG
Lieutenant JG
Posted: ‎2021-06-18 02:05 AM
7
4676
Probably many of you have at least had this issue once: you have to design a system with multiple motors and deal with motor starting, power quality, equipment sizing in the same time. Despite there are several software on the market, none is designed to do it "natively", you need to be an expert to use them and often to buy multiple packages in order to cover all sides of this design. I personally find this a bit pity, because often it is discouraging of making the analyses in depth and forces to reuse existing designs to save time. But here seems to be a solution for this dilemma. It is the recently launched calculation software named Ecostruxure Motor Management Design, dedicated to motor and network analyses with minimum effort of data and time. And it helps you to select the offers and size them, for LV and MV.
 The authors have published a short intro video here: https://www.youtube.com/watch?v=hysc9zxLEH0, but I think the best is to connect to the tool and test it by yourself. Because it does much more than shown in the video. tesys_giga_ESXMMD.png
 So, when do you connect?
  • Energy Efficiency
  • Power Quality
  • Selection & sizing
faisalamir
Lieutenant faisalamir Lieutenant
Lieutenant
Posted: ‎2021-06-18 03:12 AM
2
4670
Great job @Delcho_Penkov for what have you done to create these tools. This was useful tools indeed. I have starting to use it as engineering tool to give preliminary engineering output to tender team and our customer
Replies 7
faisalamir
Lieutenant
2
4671
Delcho_Penkov
Lieutenant JG
Posted: ‎2021-06-18 05:43 AM
In response to faisalamir
1
4649
Hi @faisalamir , thanks for this feedback! We have recently released a new version, any comments from customers or internal are welcome. Now you can also see the THDi and use the app for calculations with small motors, transformer and generator sizing!
faisalamir
Lieutenant
Posted: ‎2021-06-20 06:34 PM
In response to Delcho_Penkov
@Delcho_Penkov well noted. I will try the additional features of these tools. I will revert to you for any feedback, if any
Posted: ‎2022-12-25 10:10 PM
Hi Delcho,
I get an error when I try to reach the motor management page. Can you please cehck?
"An error occurred while processing your request.
Reference #30.756b7b5c.1672034951.2bf009ba"
thanks,
Ramazan
KrunoslavSever
Ensign KrunoslavSever Ensign
Ensign
Posted: ‎2024-09-27 05:37 AM
1627
is it possible to view influence of three drives to power quality segment? I have 3 drives of type ATV630C11N4 to simulate THD factors. Is there a tool to view harmonic generated by these drives?
Thank you.
BR,
K
AitorMartinez1
Crewman AitorMartinez1 Crewman
Crewman
Posted: ‎2025-04-23 02:28 AM
In response to KrunoslavSever
Hi @KrunoslavSever,
Yes, with EcoStruxure Motor Management Design you can view the harmonics generated by these three drives.
Best Regards,
Aitor Martínez.
Delcho_Penkov
Lieutenant JG
Posted: ‎2025-04-24 01:21 AM
Yes, you can use the same tool for that.
