Continue
  • My Subscriptions
  • Events
Switching Control Mode on ATV930 via External Signal
  • Industrial Automation
  • Solutions for Motor Management
  • Switching Control Mode on ATV930 via External Signal
BJacqz
BJacqz Mentor
49
LeoLazzaro
LeoLazzaro Troubleshooter
16
PriscilaCunha22
PriscilaCunha22 Troubleshooter
15
Altivar Process (Low Voltage)
Back to Solutions for Motor Management
JhimmyJMQT1
JhimmyJMQT1
Explorer
Posted: ‎2024-08-26 03:30 PM
1561
Dear Experts,
I hope you are doing well. I have an Altivar 930 motor drive that is being managed by a SCADA system via Profinet. I would like to configure the ATV930 so that I can switch between local and remote mode using an external pulse or selector. In local mode, the Altivar's digital inputs would be used for control. In remote mode, control would be handled by the SCADA system via Profinet.
How can I achieve this configuration?
Thank you for your assistance.
  • Drives & Motor Control
  • altivar
LeoLazzaro
Troubleshooter
Posted: ‎2024-11-03 02:49 PM . Last Modified: ‎2024-11-04 08:43 AM
Dear Jhimmy :  Please could you clarify if you need to change only the control ( start /stop) or also the speed  refernence?  FOr other side please could you clarify in remote and local how do you want to send the speed reference? It is important to know  in detail to define the correct configuration,  our drive can manage diferent setting for control and Frequency reference and different chanels . Please clarify this point and we will give you the correct configuration .
Example :
If you use Channel 1 for PRofinet start/stop  and speed reference,  and channel 2 = digital input for start/stop and analog input for  speed reference . you can do following setting in the commmand and reference menu.
CCS= DIx ( digital input selected to change between channel 1 and 2)
FR1= Ref. Freq-Com.Module=NET  => Channel 1 is assigned to the connected option com card => PRofinet
FR2= AIx (selected  analog input for reference )=> Channel 2= Digital input and analog input .
It is simple setting , after we can do more specific configuration depending your needs.
Bastian_Schmitz
Bastian_Schmitz Champion
Champion
Posted: ‎2024-09-26 01:45 AM
Check the parameter [CCS]. You could define two seperated values for command and reference. With CCS you could switch between this channels.
LeoLazzaro
Troubleshooter
Example :
