ATV6A0C71T4 and ATV6A0C25T4 heat disspation with forced air ?
  • Industrial Automation
  • Solutions for Motor Management
  • ATV6A0C71T4 and ATV6A0C25T4 heat disspation with forced air ?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Jose.Seijas
Jose.Seijas
Cadet
Posted: ‎2024-09-17 12:49 PM
563
Gentlemen,
I am in the process of calculation the air conditioning system for a building that will contain three Altivar Process Drives.
Would you mind providing the heat dissipation with forced air in the three following units ?
ATV6A0C71T4 (750HP)
ATV6A0C50T4 (600HP)
ATV6A0C25T4 (300HP)
Thanks in advance,
Jose Seijas
M&M Coastal Manufacturing
jose.seijas@mandmcoastal.com
Phone number: 305-8426683
PriscilaCunha22
Lieutenant JG
Posted: ‎2024-10-31 09:46 AM
Hello @Jose.Seijas
Good to hear that the local team already supported you.
You can find this information in the APM Integration Manual for Partners. There is a section called "Heat Losses" and you can see the diferent heat losses by Normal duty/heavy duty and separated by Power and electronic area.
Jose.Seijas
Jose.Seijas
Cadet
Posted: ‎2024-09-19 05:31 AM
Thanks for the technical table I received yesterday from you guys.
I ende using the following as part of the HVAC calculations for the building:
750HP ATV600 VFD:14800 Watts
600HP ATV600 VFD:9900 Watts
300HP ATV600 VFD: 4380 Watts
If the above is incorrect please let me know.
Thanks again,
PriscilaCunha22
Lieutenant JG
Hello @Jose.Seijas
