Internal Arc in ATV6000 drive
  • Industrial Automation
  • Solutions for Motor Management
  • Internal Arc in ATV6000 drive
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
vermas
Crewman vermas Crewman
Crewman
Posted: ‎2024-05-12 09:14 PM
697
Is there a possibility of generation of internal arc in ATV6000 drive?
How exhaust gases generated due to internal arc are safely evacuated from panel?
  • Medium Voltage AC Drives
PriscilaCunha22
Lieutenant JG
Posted: ‎2024-10-31 09:35 AM
Hello @vermas
The ATV6000 enclosure is not arc-proof.
The solution we have to limit the arc is to add an Arc Flash detection inside the enclosure.
PriscilaCunha22
Lieutenant JG
Hello @vermas
