Speed control with two potentiometer on ATV 930 drive
Solutions for Motor Management
Get support to configure, troubleshoot, update or upgrade your motor management solution built with Altivar variable speed drives and Tesys devices to start, control, protect and monitor Low Voltage and Medium Voltage motors and loads, covering direct start, soft start and variable speed control.
  • Industrial Automation
  • Re: Speed control with two potentiometer on ATV 930 drive
BJacqz
Commander BJacqz Commander
48
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
12
Bastian_Schmitz
Admiral Bastian_Schmitz Admiral
11
Back to Solutions for Motor Management
Anonymous user
Not applicable
Posted: ‎2022-12-14 06:09 AM . Last Modified: ‎2023-03-30 05:01 AM
1154
I have connected two 10kohm poti on AI1 and AI2 and high speed contact on DI3.
I want control speed from poti 1 connected to AI1 in normal operation and from poti 2 connected to AI2 when DI3 is active.
Which setting need to be configured?
  • Low Voltage AC Drives
  • Medium Voltage AC Drives
Kevin_McDonald
Ensign Kevin_McDonald Ensign
Posted: ‎2023-03-30 07:19 AM
See the [Ref 1B switching] rCb paremeter in the Command and Reference Menu.  Then you can set [Ref Freq 1 Config] Fr1 as AI1 and [Ref Freq 2 Config] Fr2 as AI2.
Also covered in our FAQs
https://www.se.com/us/en/faqs/FA294131/
Reply 1
Kevin_McDonald
This is a heading
