Rated motor current
  • Industrial Automation
  • Solutions for Motor Management
  • Rated motor current
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2022-08-10 07:13 AM
1
1416
Rated motor current
I have a VFD ( ATV310 , 1 Hp ). Rated motor current is 1.8 A. what will happen if I set the value of rated motor current value ( parameter 305 ) less than rated motor current value i.e. 1.3 or 1.4 ?
BJacqz
Commander
Posted: ‎2022-08-18 04:22 AM
The rated motor current will help to manage correctly the motor performance's during transcient's and also on stable state. In order to get the best motor performances, it is adviced to enter motor name plate (given on motor nameplate) in the drive (motor control menu), and afterward to perform an autotune (parameter 318).
The other motor parameter (motor thermal current, 604, will help managing the thermal protection of the motor.
Bruno Jacqz, Drives training leader
