TeSys Island Bring Sustainability to your Motor and Load Management
  • Industrial Automation
  • Solutions for Motor Management
  • TeSys Island Bring Sustainability to your Motor and Load Management
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys island
Back to Solutions for Motor Management
Muzaffer_Sayyed
Muzaffer_Sayyed Cadet
Cadet
Posted: ‎2022-08-05 07:38 AM
With the climate change challenges, sustainability has become one of the key levers for any industrial operations. At the same time organization are being measured for sustainability measure they took with their plant operations like energy saving  and human safety aspects, CO2 emission etc
TeSys Island can add a bit to consumers sustainability goals in following manners :
Higher transparency of energy data
TeSys Island with voltage module brings higher transparency of energy data at feeder and machine level. This can enable user to identify the losses , unused energy and voltage side issues and ways to minimize peak demands
Low operational energy & losses
TeSys Island comes with low consumption  electronic coils with reduced holding power required by 30percent then conventional coils. Also, it reduces heat losses by 34 percent lesser than conventional 3 product solution. This enables consumer to have lesser CO2 foot print while using Island based starters
Better management of resources
TeSys Island comes with pre- configured modes for applications like Pump called  AVATAR, this help in better monitoring of resources like water while integrated process inputs like pressure , level sensors etc. Features like undercurrent and overcurrent help in preventing dry run and blockages in system
Green premium offer
TeSys Island is certified green premium product from Schneider as certified for REACh, and RoHS Directive by EU. Its is manufactured by use of best and recyclable plastic products and is Halogen and mercury free. Few references covering vast application and loads causes less variants to be stocked
Less use of precious earth metals
TeSys Island is compact, modular and digitize motor and load management solutions, this eventually reduces usage of control wires, panel space and as well drastically eliminates commissioning and engineering times of users and manufactures. While using less Cu and sheet metal it also provides faster turn around time for panel manufacturers
Highest level of human safety
TeSys Island can be enhanced for  achieving SIL 3 safety for critical application like boiler, heater, cutting  etc. Island ensure safe disconnection of equipment in event of system malfunction or safety initiation to avoid any human damages or fatalities
  • Digitalization
  • Energy Efficiency
  • Power Quality
  • sustainability
Replies 0
