Overload relay
Select a Country
  • Industrial Automation
  • Solutions for Motor Management
  • Overload relay
BJacqz
BJacqz Mentor
49
LeoLazzaro
LeoLazzaro Troubleshooter
16
PriscilaCunha22
PriscilaCunha22 Troubleshooter
15
Back to Solutions for Motor Management
Posted: ‎2020-07-16 05:17 AM . Last Modified: ‎2021-03-16 09:49 AM
4038
Overload relay
What range overload relay can use 18.5 Kw motor
  • Selection & sizing
Delcho_Penkov
Delcho_Penkov Troubleshooter
Troubleshooter
Posted: ‎2021-03-16 08:54 AM
In response to JLD
Hello, another possibility is to use the online configurator, where you can specify motor power and voltage, together with the necessary control method: https://www.se.com/ww/en/work/products/industrial-automation-control/tools/motor-control-configurato...
Replies 4
Omaelk
Omaelk Leader
Leader
Posted: ‎2020-07-16 07:05 AM
Hey @Anonymous user , can you please share more details about your issue? which product?
JLD
JLD Contributor
Contributor
Posted: ‎2021-02-04 12:25 PM
2
3810
Hello
Overload realys are classified by classes; class 10, Class 20, depending how long last the acceleration step of your motor.
(Class 10 accept up to 10sec, class 20 up to 20Sec)
For class 10;  You can use LRD serie if motor In <)140A
For class 20, you could use LRD..L serie
At your disposal for more info
Rgds
JLD
JLD Contributor
Contributor
Posted: ‎2021-02-04 12:30 PM
In response to JLD
1
3808
 18,5KW , you could take for class 10; LRD380 that you can mount on a Tesys D contactor LC1D80A.. .
Delcho_Penkov
Troubleshooter
In response to JLD
