Can I give 400VAC supply to the motor rated of 415VAC?
  • Industrial Automation
  • Solutions for Motor Management
  • Can I give 400VAC supply to the motor rated of 415VAC?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2020-06-06 10:17 PM . Last Modified: ‎2021-03-16 09:48 AM
2
4159
  • Design & Build
  • Selection & sizing
MikaelKrantz
Guinan MikaelKrantz Guinan
Guinan
Posted: ‎2020-06-08 11:10 PM
1
4152
Have to say that a motor may be out of my knowledge, but many times you could check in the datasheet, the nominell voltage for the supply if given, but also a procent over and under voltage that they specify.
Delcho_Penkov
Lieutenant JG Delcho_Penkov Lieutenant JG
Lieutenant JG
Posted: ‎2021-03-15 10:31 AM
In response to MikaelKrantz
Hello, yes you can. If the motor is specified at 415V but you use it at 400 this is 3.6% lower value. For the same load power the motor will take higher current, to compensate for the lower voltage, but it is reasonable, and the motor can operate continuously. Motors can tolerate ~10% voltage variation, if nothing else is specified. Also, let's not forget that often motors are over-specified for the application and in fact do not run at full power, meaning its current will actually be lower than rated.
MikaelKrantz
Guinan
1
4153
Delcho_Penkov
Lieutenant JG
