Modbus port
  • Industrial Automation
  • Solutions for Motor Management
  • Modbus port
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
mark.lawrence.at.cseinc.com
Cadet
Posted: ‎2023-01-10 11:16 AM . Last Modified: ‎2023-03-13 02:55 AM
1512
Modbus port
can the one of the modbus ports on the Altivar 630 function like a Uni-telWay/Modbus com card on the  Altivar 61?  I am replacing a Altivar 61 that uses the Uni-telWay/Modbus com card with an Altivar 630 and need to keep the Modbus control.
  • Low Voltage AC Drives
LeoLazzaro
Lieutenant
Posted: ‎2023-03-13 10:36 AM
1473
Hi Mark :
           Thank for your question.
           Unfortunately we do not have Uni-Telway optional card  for ATV630 today . ATV630 has  Modbus RTU o Modbus TCP/IP embeded.
Thank you in advance
B.R.
Leonardo Lazzaro
Global offer Manager ATV Process.
BJacqz
Commander
Posted: ‎2023-03-14 05:06 AM
In response to LeoLazzaro
In addition to this information, please find enclosed the communication document helping you on communication parameters...
Bruno Jacqz, Drives training leader
LeoLazzaro
Lieutenant
1474
Hi Mark :
B.R.
Leonardo Lazzaro
BJacqz
Commander
