Highest Short circuit rating of Tesys U
  • Industrial Automation
  • Solutions for Motor Management
  • Highest Short circuit rating of Tesys U
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
MercedesLopez
Ensign MercedesLopez
Ensign
Posted: ‎2021-04-02 05:59 PM
1
1613
In my plant, the existing panel contains Schneider TeSys D and TeSys U contactors.
We would like to change a motor for a bigger one.
What is the highest rating we can cover with the TeSys U?
Best regards
Mercedes
  • Selection & sizing
JLD
Ensign JLD Ensign
Ensign
Posted: ‎2021-04-06 12:36 AM
Thanks for the interest you show on TeSys U .
Concerning you request about "more powerfull motor":  The TeSys U range has recently been extended up to 18,5kW /38A within the same form factor: 45mm width *154mm height.  This extension is available for both 1 way motors and 2ways-motors. Also,  Like current range , this extension can be equipped with the 3 types of Control unit: LUCA, LUCB and LUCM,  and is compatible with all Communication units available on the catalog.
Regarding your question about short circuit rating:   TeSys U performances are the following: 50kA/480Vac   but can be extended up to 130KA/480Vac with the use of Current limiters modules. (LUALB1 or LA9LB820)
I hope this brings the clarifications you need.
At your disposal
Rgds
JL Delage
JLD
Ensign JLD Ensign
Ensign
At your disposal
Rgds
JL Delage
