Posted: 2021-03-26 12:04 AM . Last Modified: 2021-04-12 02:01 AM
Hello, I need to set a safety function inside ATV320, could you tell me how to proceed ?
Posted: 2021-03-26 02:48 AM . Last Modified: 2021-03-26 06:43 AM
The safety function inside Drives is set using SoMove software. This allows a complete acess of safety functions.
SoMove will bring you a along the configuration and allowing you to see the different available parameters.
At the end of settings action, it is possible to get a report of what was done. This gives an overview of situation on setting of the Drive inside installation.
Some example of this programing is shown inside our How to data base available on internet .
Here is the video :
Here is the video :
