Which PLC can be connected to TeSys island?
  • Industrial Automation
  • Solutions for Motor Management
  • Which PLC can be connected to TeSys island?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys island
Back to Solutions for Motor Management
Posted: ‎2021-03-26 01:45 AM
1
1914
Is it only Schneider Electric PLCs or can we connect equipment from other manufacturers?
Thanks in advance for your answer
  • Design & Build
  • Selection & sizing
  • TeSys island
TeSys_island
TeSys_island Schneider Alumni (Retired)
Posted: ‎2021-03-26 02:49 AM
Hello MikaelKoch
you can connect to all PLC´s with the supported field bus. We are integrated in Machine Expert, Tia Portal and the Studio 5000. For the PLC´s who are using this programming software the efforts are lower.
Supportet Field Bus are EthernetIP, ModbusTCP, Profinet and Profibus.
  • TeSys island
TeSys_island
Hello MikaelKoch
  • TeSys island
