Error 1006 atv 320 drives
  • Industrial Automation
  • Solutions for Motor Management
  • Error 1006 atv 320 drives
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Cavwheatley
Cavwheatley
Cadet
Posted: ‎2024-12-23 04:00 AM
1002
Just looking for a bit of help with a new vfd.  We had a shaker, and a 5hp vfd configured with ethernet communication for control.  They removed the shaker and put a 7.5 hp motor for a pump in its place.  I tried to load the shaker program in, change the vfd my device settings to match the new vfd but I'm not sure what else to change for the software to load tge program into the new vfd.  I get an "Error 1006" message about the dtm not.matching  the device topology.  Looking for a way to correct this.  I'm a novice user at best so any help would be greatly appreciated
Kevin_McDonald
Ensign Kevin_McDonald Ensign
Ensign
Posted: ‎2025-01-21 05:16 AM
We recently came across this in the USA support team.  We found that the customer was trying to load a SoMove file into the ATV320 drive that was missing an option card.  Physically check the drive slots to confirm that you are not missing the option card as part of the programming.
Alternatively, contact your local Country CCC to initiate a technical support case to follow up on your specific issue.
Schneider_Laure
Crewman Schneider_Laure
Crewman
Posted: ‎2025-01-29 12:23 AM
Error 1006 indicates a mismatch between the device's physical configuration (topology) and the DTM configuration. To resolve this:
  1. Verify the device reference and power rating (see device nameplate) against the DTM configuration.
  2. Confirm that any installed option modules match the DTM configuration
  3. Change the topology before transferring the configuration to ensure the power rating and option cards are consistent between the SoMove configuration and the remote drive.
Kevin_McDonald
Ensign
Schneider_Laure
Crewman
