ATV320 IP66
  • Industrial Automation
  • Solutions for Motor Management
  • ATV320 IP66
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Episteme
Episteme
Cadet
Posted: ‎2025-01-27 12:28 PM
395
ATV320 IP66
Does the ATV320 Drives accept 2 feed wires directly on its terminals L1, L2, and L3?
Does it say so in the literature somewhere?
  • Drives & Motor Control
Schneider_Laure
Crewman Schneider_Laure
Crewman
Posted: ‎2025-01-29 12:14 AM
Hello Episteme, you can find all the wiring details in the Installation Manual:
The manual is available for download here:
https://www.se.com/es/es/download/document/NVE41289/
If you need to wire more than 1 cable in the same terminal, you have to use ring type cable lugs or wire ferrules
For example, the motor terminal in a Drive Frame Size 6 cannot exceed 35 mm² (the terminal's maximum permissible cross-sectional ar permissible cross section of the terminal)
