Discover now the new generation of TeSys Deca Series motor starters.
  • Industrial Automation
  • Solutions for Motor Management
  • Discover now the new generation of TeSys Deca Series motor starters.
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
ClaudiaCombei
Crewman ClaudiaCombei Crewman
Crewman
Posted: ‎2021-11-08 05:00 AM . Last Modified: ‎2021-11-08 05:30 AM
To address the modern requirements of the HVAC, electro-domestic, elevator and harsh environment industries, we’ve upgraded the original TeSys GV2~3 and TeSys D.
This new generation TeSys Deca Series offers a more robust and innovative one-stop solution, with new technical features. The new generation TeSys Deca Series guarantees consistent performance and great functionality, so you get the simplest and most efficient solution possible.
  • EN60335-1 standard compliant plastic: new TeSys Deca contactors use higher grade plastics for better fire resistance, ensuring they are compliant with the EN60335-1 standard for electro-domestic applications and the HVAC industry, while offering enhanced simplicity and efficiency when it comes to use.
  • Multi-standard screw: installation is faster and easier than ever before with the multi-standard screw, which is compliant with most frequently used Philips, Pozidriv and flat head screwdrivers.
  • New dust-proof auxiliary contact:  the new and improved add-on/front auxiliary contact has been upgraded from 5 mA to 1 mA for high-contact reliability across all applications, resulting in smoother automation. The red cover also makes it easier to identify the safety chain, guaranteeing a better customer experience.
  • QR codes: you can easily and conveniently access technical information and instruction sheets via QR codes.
  • Eco-friendly packaging, which is made from lead-free ink and recycled carton
The new TeSys Deca Series is a greener, more robust, more efficient and more reliable solution, thanks to its range of new features. This game-changing series now also comes with a sleek dark-grey design, for a more modern look and feel.
  • Design & Build
  • Energy Efficiency
  • Products
Replies 0
