Select a drive depending on temperature
Select a Country
  • Industrial Automation
  • Solutions for Motor Management
  • Select a drive depending on temperature
BJacqz
BJacqz Mentor
49
LeoLazzaro
LeoLazzaro Troubleshooter
16
PriscilaCunha22
PriscilaCunha22 Troubleshooter
15
Altivar Machine
Back to Solutions for Motor Management
Posted: ‎2021-04-16 02:38 AM
3
2909
Hi everyone, I need to mount my ATV320 in an ambient temperature of 55°C, is it possible ?
Thank you for your support!
  • Selection & sizing
  • Altivar Machine
  • atv320
Arth_Industry
Arth_Industry Contributor
Contributor
Posted: ‎2021-04-16 05:16 AM
1
2900
Hi.
In this case you will need to derate.
Arth_Industry
Contributor
1
2901
Hi.
Posted: ‎2021-05-05 12:37 AM
In response to Arth_Industry
Thank you @Arth_Industry  for your answer, very helpful.
BJacqz
BJacqz Mentor
Mentor
Posted: ‎2021-10-06 04:21 AM
In addition to what was told, there is also another topic to take in account during the commissionning.  The motor Switching frequency ! this is the frequency of motor signal (not the motor frequency, generally between 0 to 50Hz), this is the switching frequency coming from DC bus and transforming this DC signal to AC PWM signal.
It means a switching from 2kHz or 4kHz up to 16kHz. This switching frequency will generate a noise in motor and this noise will be lower and lower when the frequency increase. The point to take in account is when you increase this setting (SFR) the losses in power module of drive increases, then the drive must be derated.
You get the table of derating inside ATV320 installation manual.
example : Capture derating SFR.PNG
Bruno Jacqz, Drives training leader
