Posted: 2021-11-08 07:17 AM
Hello Member,
The SLS safety function for Altivar 320 is an embedded function, it means you do not need any external option to get it as it is included. As it is a Safety function, it is necessary to use SoMove Software in order to program it inside the product. The software will guide you all along the programing and will show you the way to program it. The only condition is you have to be connected to the drive to configure the drive.
the SLS function is a special function to slow down or maintain a frequency to a predifined value following a monitored ramp. there are complete description of this function in the dedicated Safety 320 manual (link to the manual : https://www.se.com/ww/en/download/document/NVE50467/)
Hello Member,
