Altivar 930 gsd profinet file
Send InviteCancel
Posted: 2022-08-1609:39 PM
Where can I get the GSD files for Profinet for the Altivar930 Drive. I want to install with Siemens 840dsl. I am using simatic manager step 7 for plc. So please give me suggestion how to configure this profinet drive
