Altivar Smart Widget - Pre-engineered Variable Speed Drives in BMS (Ecostruxure Building Operation)
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar Smart Widget - Pre-engineered Variable Speed Drives in BMS (Ecostruxure Building Operation)
BJacqz
Commander BJacqz Commander
48
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
13
Bastian_Schmitz
11
Back to Solutions for Motor Management
sesa253016_brid
sesa253016_brid Schneider Alumni (Retired)
Posted: ‎2022-02-14 05:23 AM . Last Modified: ‎2022-12-02 04:10 AM
5
4227
VSDs today act as super sensors to collect rich and valuable data that can help to unleash the full potential of smart buildings. It is vital to have these data connected, analyzed, and presented in Building Management System. Altivar Smart Widget is a free, tested, validated pre-engineered Variable Speed Drive (VSD) management tool in EcoStruxure™ Building Operation – Building Management System Platform.
With Altivar Smart Widget for ATV212 and ATV630/650, facility managers (FM) and EcoXpert System Integrators can easily access critical information, control and maintenance parameters with a visualized user interface to optimize and maintain their assets without a need of Variable Speed Drive (VSD) expertise.
Altivar Smart widget allows FM’s and EcoXperts to act agile in detecting problems and application parameter changes. Smart widget translates the language of VSD to facility manager language with the advantage of remote controlling.
Altivar Smart Widget helps customers to achieve:
•Increase in engineering efficiency with pre-engineered integration with VSD
‒Decrease time in commissioning of the VSDs
•Better energy efficiency
‒Better understanding of the information coming from VSD
‒Control and optimize the parameters
•Better operational efficiency
‒Diagnostics
‒Access to warning/fault history and explanations
•Equipment availability and safety
‒Eliminate failures before happening by monitoring critical parameters
‒Schedule maintenance and ensure machine continuity
Please check out the video:
Please find the tested and validated commissioning manuals here (these documents will be available on se.com soon):
ATV212:
On se.com: https://www.se.com/ww/en/download/document/JYT47671/
ATV630:
On se.com: https://www.se.com/ww/en/download/document/JYT47674/
And you can find the xml files here:
ATV212: https://schneider-electric.box.com/s/787v313ixmbggsvrfni7smx20a44s56d
ATV630:  https://schneider-electric.box.com/s/43k05l4h8rlmt8oz7ozs58cy72xehz9l
sesa253016_brid
Posted: ‎2022-03-21 10:04 AM . Last Modified: ‎2022-03-23 09:20 AM
In response to Stuart_Aldred
4027
You can find the tested and validated commissioning manual here:
ATV212: https://www.se.com/ww/en/download/document/JYT47671/
ATV630: https://www.se.com/ww/en/download/document/JYT47674/
And you can find the ATV212 xml file here: https://schneider-electric.box.com/s/787v313ixmbggsvrfni7smx20a44s56d
ATV630 xml will be updated here soon.
Hope this helps you.
Best regards
Dinc
Replies 5
Stuart_Aldred
Ensign Stuart_Aldred Ensign
Ensign
Posted: ‎2022-03-17 08:25 AM
4107
Looks great , where can we find or install it from to run on a site?
Its not on Asset Library.
sesa253016_brid
4028
Best regards
Dinc
Stuart_Aldred
Ensign
Posted: ‎2022-06-27 05:07 AM
In response to sesa253016_brid
2881
I have not got access to the Box folder.Do you know who owns that or put the XML on here to test out please?
sesa253016_brid
Posted: ‎2022-06-28 11:56 PM
Dear Stuart,
You can directly contact your local Schneider Contact (can be asked from drives or digital energy product manager).
Or you can send me e-mail asking it by introducing yourself, country.
Best regards
Dinc
SESA30086
SESA30086 Cadet
Cadet
Posted: ‎2022-07-28 01:14 AM
Hi Dinc
The link to the ATV212 xml file doesn't work, can you correct the link or make the file available another way please
Regards
