Posted: 2025-06-30 05:05 AM
Posted: 2025-09-18 03:59 AM
Hello @Mohamed-ATV , this usually happens when the motor data is inconsistent and doesn’t make sense for the drive.
The most common reasons are:
In such cases, the system may also display a motor scaling warning.
A practical solution is to reset the motor data to the factory default settings. After doing this, the warning should disappear.
