Posted: 2022-10-16 08:00 AM . Last Modified: 2023-06-09 02:55 AM
To command an ATV320 at 50 Hz using CANopen I must pass the velocity value 1500.
Why is that? Is there any velocity scaling factor?
The only scaling factor i see is the SdS parameter but it should only change the way the speed is displayed on the drive HMI, not the way is scaled for fieldbus control.
Thank you
