Posted: 2023-11-16 09:21 PM
Let me ask about ATV310HD11N4E, customer used 4pcs of ATV310 and protect with one MCCB. When they input upgrade address in PLC to command the drive via Modbus communication, drive can’t read and Stop/reset button doesn’t work even changed the parameter code 400 & 700 as per user ATV310 manual. However, drive can run with upgrade parameter after power cycle.
How about Drive code 200 I/O Menu, this also need to do power cycle after every single input configuration changed from PLC?
Thanks in advance for your all feedback.
Ame
Posted: 2023-11-17 04:52 AM
Thank you for the question
