VILT Example Question
  • Industrial Automation
  • Solutions for Motor Management
  • VILT Example Question
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
sesa495840_brid
Crewman sesa495840_brid Crewman
Crewman
Posted: ‎2023-11-14 02:02 AM
3
1280
Does the ATV6000 use the same Optional fieldbus module cards as the LV Process Range?
Example for Profinet or Profibus communication 🙂
@BrownSugar
  • Medium Voltage AC Drives
Th-Renard
Ensign Th-Renard Ensign
Ensign
Posted: ‎2023-11-15 03:14 AM
yes, and you can see the compatibility table on the page 2 of the instruction sheet, S1A45591
here :
files (schneider-electric.com)
PriscilaCunha22
Lieutenant JG
Posted: ‎2023-11-15 12:46 AM
Hello Alex
Yes for ATV6000 we're using the same communication cards.
You can see them in the Handbook pages 247 up to 249.
https://www.se.com/us/en/download/document/QGH83255/
Th-Renard
Ensign
here :
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2023-11-17 04:51 AM
Thank you for the question
