ATS480 INSIDE DELTA
  • Industrial Automation
  • Solutions for Motor Management
  • ATS480 INSIDE DELTA
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
v4or1s
Ensign v4or1s
Ensign
Posted: ‎2025-06-02 06:44 AM
539
ATS480 INSIDE DELTA
Dear,
I need help to configure an ATS480 for inside Delta start.
I tried to start but i always have the fault change 123 to 231. (i make the change on the input wires but the fault remains)
My configuration is with main contactor. ( I set R3 to mains contactor ).
Start - Stop on start stop inputs, Reset on DI3.
R2 is set by it self on bypass contactor.
I also attached the somove file.
Can you please give me an advice what might be wrong. It is important to have a fast reply.
ARS480 DELTA INSIDE TEST.zip
  • Soft Starters
  • ATS480
  • soft starter
BJacqz
Commander
Posted: ‎2025-06-04 01:27 AM
What is important on this type of wiring is to follow the right cabling (wire to wire) from the user's manual. Do not reverse any of them, it will create a fault...
Bruno Jacqz, Drives training leader
BJacqz
Commander
