Which port number should be defined in SmartConnector extension - "Enterprise Central" or "Enterprise Server"?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Which port number should be defined in SmartConnector extension - "Enterprise Central" or "Enterprise Server"?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-06-15 06:13 AM
2687
We are using EBO 3.3 using Enterprise Central and Enterprise Server. Which port number should be defined in the SmartConnector extension - the "Enterprise Central" port number or "Enterprise Server" port number?
For example, if port 81 is used for the Enterprise Central HTTP port and port 82 is used for the Enterprise Server, which of the following addresses should be used in the EWS Connection?
http://localhost:81/EcoStruxure/DataExchange
or
http://localhost:82/EcoStruxure/DataExchange
Thank you.
Mike
ardak
Posted: ‎2021-06-15 11:02 PM
The Enterprise Central can host several Enterprise Servers which in turn host controllers like the AS-P.
If you have an Enterprise Central it is at the top of your hierarchy and is probably your main server.
BR
Armend
JeffBowman
Sisko
Posted: ‎2021-06-15 07:10 AM
2683
Hi Michael,
Either can be used depending on what server you want to connect to. If your Enterprise Central is your main server, then you should use that.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2021-06-15 08:00 AM
2680
Jeff,
Thanks. How can I know which is my main server? Can you please explain the idea beyond the Enterprise central?
Mike
ardak
BR
Armend
