Unsure how to configure Endpoint to get value from EBO
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Unsure how to configure Endpoint to get value from EBO
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Swetha_S
Ensign Swetha_S
Ensign
Posted: ‎2022-04-15 10:11 PM
5
2269
I installed smart connector in one system and EBO in another system
both are connected to same network
I created EcoStuxure Web Service interface in EBO for interfacing smart connector
Please advice us how to configure the endpoint to get EBO Values in smart connector
where to configure my EBO
IP address in smart connector
Attached the images for reference
Please advice as to resolve this issue
Replies 5
Swetha_S
Ensign Swetha_S
Ensign
Posted: ‎2022-04-19 05:05 AM
2146
Thank you sir
We will try this
Swetha_S
Ensign Swetha_S
Ensign
Posted: ‎2022-04-26 12:47 AM
2042
We now configured endpoint but unable to fetch values from the EBO Error 404 is coming when we try to fetch values in the swagger link
In swagger link we logged in and entered EWS ID to fetch value the response code is 404 no values came
Configured EBO using Service URL : http://localhost:81/EcoStruxure /DataExchange
In Smart connector used Runtime Developer License
Used SOAP REST Provider to configure Endpoint
In Server Address used :  http:// (ES IP address):81/ EcoStruxure/DataExchange
ardak
Posted: ‎2022-04-26 10:43 PM
2026
You have to double URL encode the fields where it tells you. In this case, the "id" field looks like it's not encoded.
There are a lot of tools online that can help you do this for testing, here's one example
--Armend
Swetha_S
Ensign Swetha_S
Ensign
Posted: ‎2022-04-27 10:20 PM
Thank you we will try this
Daniel_Cerone
Lieutenant JG Daniel_Cerone Lieutenant JG
Lieutenant JG
Posted: ‎2023-07-25 06:02 AM
search for the smartconnector success kit on this forum- it has a url encoding tool in it to make this easier.  also explains how to do calls.
/dcer
