The underlying provider failed on Open. Login failed for user 'REG02\CHI02FRIG48873$'. Reason: Server is in single user mode. Only one administrator can connect at this time.
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • The underlying provider failed on Open. Login failed for user 'REG02\CHI02FRIG48873$'. Reason: Server is in single user mode....
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-01-22 07:53 AM
1252
Our customer in Canada (Chicoutimi Hospital, Quebec) has the following problem. The SmartConnector stopped working yesterday. The SmartConnector log file shows this error:
2021-01-21 21:01:29.2693,Error,Service,<no principal>,The underlying provider failed on Open.
à System.Data.Entity.Core.EntityClient.EntityConnection.Open()
à System.Data.Entity.Core.Objects.ObjectContext.EnsureConnection(Boolean shouldMonitorTransactions)
à System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
à System.Data.Entity.Core.Objects.ObjectQuery`1.<>c__DisplayClass7.<GetResults>b__5()
à System.Data.Entity.Infrastructure.DbExecutionStrategy.Execute[TResult](Func`1 operation)
à System.Data.Entity.Core.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
à System.Data.Entity.Core.Objects.ObjectQuery`1.<System.Collections.Generic.IEnumerable<T>.GetEnumerator>b__0()
à System.Data.Entity.Internal.LazyEnumerator`1.MoveNext()
à System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
à Mongoose.Service.Licensing.AntiRollbackDateTime.get_UtcNow()
,["Current WindowsIdentity is NT AUTHORITY\\SYSTEM"],
à Mongoose.Service.Mongoose.HasValidFrameworkLicense()
Any idea what is causing this error?
Thank you.
Michael
JeffBowman
Sisko
Posted: ‎2021-01-22 08:20 AM
1250
Hi Michael,
The error states that SQL is configured to only accept a single admin user being connected a time. This seems like it's potentially a configuration issue on the customers database. I would have them look into this.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2021-01-22 08:41 AM
Hi Jeff,
Thank you. I will let them know.
Best regards,
Mike
