The underlying connection was closed: A connection that was expected to be kept alive was closed by the server
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • The underlying connection was closed: A connection that was expected to be kept alive was closed by the server
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-01-05 04:28 AM
2318
Our processor is closed by the server after ~16 seconds.
See below. Any idea what may be the reason? The log file is attached.
2021-01-05 14:03:04.9695,Info,WorkerThread,<no principal>,EBO Alarm Item Discovery Processor,Started,
2021-01-05 14:03:20.0901,Error,Processor,<no principal>,EBO Alarm Item Discovery Processor,System.ServiceModel.CommunicationException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. ---> System.Net.WebException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
at System.Net.HttpWebRequest.GetResponse()
at System.ServiceModel.Channels.HttpChannelFactory`1.HttpRequestChannel.HttpChannelRequest.WaitForReply(TimeSpan timeout)
--- End of inner exception stack trace ---
2021-01-05 14:03:20.0930,Info,Processor,<no principal>,Validation Prompt for EBO Alarm Item Discovery Processor: MayNotContinue : The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
Thank you.
Mike
2021-01-05.log
mike_meirovitz
Commander
Posted: ‎2021-01-05 07:52 AM
2311
Hi Jeff,
The EBO server was not restarted during the processor run.
Yes, it happens consistently.
Thank you.
Mike
Replies 4
JeffBowman
Sisko
Posted: ‎2021-01-05 07:44 AM
2313
Hi Michael,
This could be that the EBO server restarted during the processor run.
Does this happen consistently?
Best Regards,
-Jeff
mike_meirovitz
Commander
2312
Hi Jeff,
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2021-01-05 08:49 AM
2308
Hi Michael,
Could this be the same issue you have seen in the past with http vs https and the certificates?
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2021-01-05 10:42 AM
Hi Jeff,
I'll check tomorrow with the customer.
Thank you.
Mike
