There was no listening endpoint on http://localhost/ EcoStruxure/DataExchange that could accept the message
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • There was no listening endpoint on http://localhost/ EcoStruxure/DataExchange that could accept the message
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-01-22 08:10 AM
1122
Our customer in Canada (Chicoutimi Hospital, Quebec) sent me the SmartConnector below with this errors (in French language)
2021-01-21 07:09:49.2920,Error,Processor,<no principal>,Il n'existait pas de point de terminaison à l'écoute sur http://localhost/EcoStruxure/DataExchange pouvant accepter le message. Ceci est souvent dû à une adresse ou une action SOAP incorrecte. S'il est présent, voir l'élément InnerException pour plus d'informations.
Le serveur distant a retourné une erreur : (404) Introuvable.
After translation to English the text is:
There was no listening endpoint on http://localhost/ EcoStruxure/DataExchange that could accept the message. This is often due to an incorrect SOAP address or SOAP action. If present, see the InnerException element for more information.
The remote server returned an error: (404) Not found.
Can you please explain what is causing this error?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2021-01-22 08:33 AM
1120
Hi Michael,
Two potential issues:
1. The EWS address is not correct, either because the hostname, or port is incorrect.
2. EWS is disabled in EBO.
Can you check both of these?
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2021-01-22 08:45 AM
Hi Jeff,
Thank you. We will check these 2 potential issues.
Mike
