SmartConnector v2.4.21 - SOAP EWS REST Provider Endpoint - Throttling Policy
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector v2.4.21 - SOAP EWS REST Provider Endpoint - Throttling Policy
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Chris_154851
Lt. Commander Chris_154851 Lt. Commander
Lt. Commander
Posted: ‎2019-08-12 11:20 PM
1864
I have recently installed SmartConnector v2.4.21 and configure some EndPoints as SOAP EWS REST. The Integration Platform which is connecting to these requires rates per minutes increased. I have done this in previous version under the Throttle Policy for each EndPoint.
This version does not appear to have this. I checked the SmartConnector RESTful EWS Gateway document and it is still mentioned within.
2019-08-13 15_08_46-ES-CCT10-01 (10.10.101.101) - Remote Desktop Connection Manager v2.7.png
I had initially been using Chrome, so I have installed FireFox and it is still not present. I also inspected the page with Chrome and searched for throttle in case it was not loading the page in a way I could see the Throttle Policy branch of the tree.
Has this been moved somewhere else? Do I need to enable something? Or have I mucked up the install somehow?
Any help would much appreciated.
Tags (5)
  • endpoint
  • policy
  • throttle
  • throttling
  • v2.4.21
JeffBowman
Sisko
Posted: ‎2019-08-13 06:28 AM
1860
Hi Chris,
I just took a look and it looks like it is in the same spot it has always been. I am in 2.4.21. Can you try and re-create the SOAP gateway? I have no idea why it would just dissapear!
Best Regards,
-Jeff
JeffBowman
Sisko
1861
Hi Chris,
Best Regards,
-Jeff
Chris_154851
Lt. Commander
Posted: ‎2019-08-13 04:01 PM
Hi Jeff,
Well this is weird, I recreated as suggested and the Throttling Policy is now there. I had an Enterprise Server and several AS-P set up as end points and none of them had the Throttling Policy.
I can only guess there was some error in the one I cloned and it replicated through.
Cheers,
Chris
Chris_154851
Lt. Commander
Posted: ‎2019-08-13 04:28 PM
Hi Jeff,
After recreating some of the EndPoints again I went back to check the one I was "cloning" it from and the "Throttling Policy" has disappeared again.
It looks like if I use a configured endpoint as the original for cloning once or twice it has the "Throttling Policy" disappear. The work around is I will create each EndPoint from new rather than cloning, just a bit more time consuming having to re-enter all the details.
Cheers,
Chris
