Error message "Data at the root level is invalid. Line 1 position 1" when I try to login to SmartConnector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Error message "Data at the root level is invalid. Line 1 position 1" when I try to login to SmartConnector
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2019-08-13 05:33 AM . Last Modified: ‎2019-08-30 06:04 AM
1152
The SmartConnector portal asked me to change my password. After the password was changed and tried to log in.
Then the error message "Data at the root level is invalid. Line 1 position 1" is displayed repeatedly.
Any idea how to fix it?
Thanks.
Mike
mike_meirovitz
Commander
Posted: ‎2019-08-31 12:20 AM
1
1138
The problem was caused by the Chrome Extension called Grammatically. Once the extension was uninstalled, the problem was resolved. Thanks to Jeff Bowman who help me solving this problem.
Mike
Posted: ‎2019-08-30 05:59 AM . Last Modified: ‎2019-08-30 06:09 AM
1143
Hi @mike_meirovitz ,
I have noticed that your topic is still unanswered.
I was wondering if you still have this error or find a solution on your side. If so, I kindly invite you to press the button "accept as solution".
If you still haven't found a solution, please do not hesitate to inform us.
N.B : I took the liberty of changing the title of your topic for a better reference on this community.
mike_meirovitz
Commander
1
1139
Mike
Posted: ‎2019-09-02 12:36 AM
Thank you very much for your answer @mike_meirovitz!
Good to read that your problem is solved thanks to @JeffBowman.
Have a great day!
