I made a extension and test extension. but when I tried Execute Test/Debug Selected Test I am getting error:
"An exception of type 'System.NotImplementedException' occurred in Hbys.Extension.Test.dll but was not handled in user code"
I added to app.config ;
<connectionStrings>
<add name="SmartConnectorDb" providerName="System.Data.SqlClient" connectionString="Server=localhost\SQLEXPRESS;Database=SmartConnector.Service;User Id=sa;Password=123456" />
<add name="SmartConnectorUserDb" providerName="System.Data.SqlClient" connectionString="Server=localhost\SQLEXPRESS;Database=SmartConnector.User;User Id=sa;Password=123456" />
</connectionStrings>
<appSettings>
<add key="EncryptionKey" value="xddadadsaasd" />
</appSettings>
what is the problem? how can I solve?
Hi Jeff,
I tried to add test again. when I finish everthing there is error;
maybe it can help you. then I click add to reference everthing is looking ok when I rebuild.
On another extension and test.extension it is working on same computer. I can debug.
Hi Kanber,
Can you post your test fixture code here?
Best Regards,
-Jeff
Hi Jeff,
there is the code;
using System;
using Mongoose.Common;
using Mongoose.Configuration;
using Mongoose.Process;
using Mongoose.Test.Processors;
using SxL.Common;
using NUnit.Framework;
using SmartConnector = Mongoose.Service.Mongoose;
using Fire.Extension;
namespace Hbys.Extension.Test
public class HbysDiscoveryProcessorTestFixture : IProcessorTestFixture<FireDiscoveryProcessor>
#region FixtureSetup
[OneTimeSetUp]
public void FixtureSetup()
try
SmartConnector.InitIoC();
catch (Exception ex)
Logger.LogError(LogCategory.Testing, ex);
throw;
#endregion
#region CreateTestableProcessor - IProcessorFixture Member
private FireDiscoveryProcessor _processor;
public FireDiscoveryProcessor CreateTestableProcessor()
if (_processor != null) return _processor;
Type processorType;
ActivatorHelper.ActivateObject<Processor>("Fire.Extension.dll", "Fire.Extension.FireDiscoveryProcessor", out processorType);
var config = ProcessConfiguration.ExtractConfiguration(processorType);
_processor = config.InstantiateInstance() as FireDiscoveryProcessor;
Assert.NotNull(_processor, "Could not create a testable processor");
return _processor;
#endregion
#region ValidateTest - IProcessorFixture Member
[Test]
public void ValidateTest()
throw new NotImplementedException();
#endregion
#region CancelTest - IProcessorFixture Member
[Test]
public void CancelTest()
this.RunCancelTest();
#endregion
#region ExecuteTest - IProcessorFixture Member
[Test]
public void ExecuteTest()
this.RunExecuteTest();
FireDiscoveryProcessor IProcessorTestFixture<FireDiscoveryProcessor>.CreateTestableProcessor()
#endregion
