SmartConnector extension - alarm discovery processor finds 0 alarms
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector extension - alarm discovery processor finds 0 alarms
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2022-03-29 02:40 AM
4174
We have a customer (Schneider Electric in USA) that is using our product (UCME-SmartConnector).
The product contains a SmartConnector extension with 2 processors.
One processor works fine with no problems.
The second processor is an Alarm Discovery processor. According to the SmartConnector log file, the discovery processor starts and ends successfully, however, it discovers 0 alarms instead of ~200 alarms that are defined in the EBO and in one ASP. See the log below.
2022-03-28 17:10:25.2794,Info,Processor,<no principal>,EBO Alarm Item Discovery Processor,Execute_Subclass starting...,
2022-03-28 17:10:25.2794,Info,Processor,<no principal>,EBO Alarm Item Discovery Processor,Ucme.Extension.dll version: ,1.0.0.28,
2022-03-28 17:10:25.2794,Info,Processor,<no principal>,EBO Alarm Item Discovery Processor,ExtractAlarmItems, UCME Folder = ,C:\Program Files (x86)\Control-See\UCME-SmartConnector,
2022-03-28 17:10:25.3154,Trace,Service,<no principal>,Validating framework license,
2022-03-28 17:10:25.3723,Debug,Processor,<no principal>,EBO Alarm Item Discovery Processor,Getting alarm messages for 0 alarms..,
2022-03-28 17:10:25.3723,Info,Processor,<no principal>,EBO Alarm Item Discovery Processor,ExtractAlarmItems, alarmItems count = ,0,
2022-03-28 17:10:25.3723,Info,Processor,<no principal>,EBO Alarm Item Discovery Processor,ExtractAlarmItems, augmentedAlarm count = ,0,
2022-03-28 17:10:25.3723,Debug,Processor,<no principal>,Processor EBO Alarm Item Discovery Processor Execute completed,
2022-03-28 17:10:25.3723,Debug,WorkerThread,<no principal>,EBO Alarm Item Discovery Processor,Execute (end),2022-03-28T21:10:25,ET=317 mSec,
2022-03-28 17:10:25.3723,Info,WorkerThread,<no principal>,EBO Alarm Item Discovery Processor,Ended successfully,
Any idea what may cause this problem?
Note: This processor worked as expected before(in February). The only change in the system is that the customer started using HTTPS connection rather than HTTP that was used before.
Thank you.
Mike
Replies 14
ardak
Posted: ‎2022-03-29 03:05 AM
4167
Please turn on EWS consume logging and try to run it, it should give you an insight into the requests that are sent by your processor.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2022-03-29 05:51 AM
4155
Hi Armend,
Thank you for your answer. See the attached log file and also below.
2022-03-29 08:39:20.7493,Debug,EwsConsume,<no principal>,GetUpdatedAlarmEvents,f5c9ba94-733f-4264-a9bd-7644b4ad4533,Request,{"GetUpdatedAlarmEventsParameter":{"LastUpdate":"e0c5b5a9-0bf0-4215-8f88-dff1bdc2afbd|6866","MoreDataRef":""},"GetUpdatedAlarmEventsFilter":{"PriorityFrom":"1","PriorityTo":"1000","Types":[]},"version":"1.2"},
2022-03-29 08:39:20.7493,Debug,EwsConsume,<no principal>,GetUpdatedAlarmEvents,f5c9ba94-733f-4264-a9bd-7644b4ad4533,Response,{"GetUpdatedAlarmEventsResponseStatus":{"MoreDataAvailable":false,"MoreDataRef":"","LastUpdate":"e0c5b5a9-0bf0-4215-8f88-dff1bdc2afbd|6866","NeedsRefresh":false},"GetUpdatedAlarmEventsAlarmEvents":{"AlarmEvent":null,"Metadata":null},"version":"1.2"},
2022-03-29 08:39:20.7493,Info,EwsConsume,<no principal>,GetUpdatedAlarmEvents,ET=2 mSec,
As far as I understand the returned data is null.
I appreciate your advise.
Thank you.
Mike
2022-03-29_after_ews_consume_true.log
ardak
Posted: ‎2022-03-29 06:21 AM
4153
It looks like you are doing a GetUpdatedAlarmEvents call with a LastUpdate already in memory
2022-03-29 08:39:20.7493,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from https://172.16.20.13:443/EcoStruxure/DataExchange with last update: e0c5b5a9-0bf0-4215-8f88-dff1bdc2afbd|6866
This will only get alarms since that last update. If no alarms have gone active since, the response will be empty.
I don't know how your code works, but you might need to clear the LastUpdate or do a "GetAlarmEvents" to "refresh" the old alarm data if it has been "lost" in your processor.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2022-03-29 06:32 AM
Hi Armend,
Thank you for your answer. Note: the discovery processor scans the EBO tree for defined alarms - Not active alarms.
Note that there is another processor running in parallel - the Push Processor.(which is running with no problems). It is possible that this processor is responsible for the "GetUpdatedAlarmEventsResponseStatus" lines in the SmartConnector log file.
I assume you can't tell from the log file which processor is causing the "EwsConsume" line in the log file. Correct?
Any other idea?
Thanks.
Mike
ardak
Posted: ‎2022-03-29 10:25 PM
4102
Ok!
2022-03-29 08:39:48.9487,Debug,EwsConsume,<no principal>,GetContainerItems,1c5f28e5-4284-44e4-8c08-907150ea66cb,Request,{"GetContainerItemsIds":[""],"GetContainerItemsParameter":null,"version":"1.2"},
2022-03-29 08:39:48.9673,Debug,EwsConsume,<no principal>,GetContainerItems,1c5f28e5-4284-44e4-8c08-907150ea66cb,Response,{"GetContainerItemsItems":[],"GetContainerItemsErrorResults":[{"Id":"00/Server 1","Message":"INVALID_ID"}],"GetContainerItemsStatus":null,"version":"1.2"},
For some reason the EBO server is not accepting the GetContainerItems request with no id(GET root). What version of EBO is this?
mike_meirovitz
Commander
Posted: ‎2022-03-30 09:02 AM
4084
Hi Armend,
The EBO version is 3.2.3.59.
Thank you.
Mike
ardak
Posted: ‎2022-03-30 10:36 PM
4070
Ok!
It looks to me like Smartconnector is sending the request correctly but isn't getting a proper response. Feel free to create an issue with PSS and provide the logging I highlighted.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2022-03-30 11:55 PM
4062
Hi Armend,
Thank you. Can you please explain what PSS means? How can I create an issue?
Mike
CraigEl
Administrator CraigEl Administrator
Posted: ‎2022-03-31 12:12 AM
4057
@mike_meirovitz PSS is an old acronym for our Expert Support team. You should contact you local SE customer care organization to start a case. https://www.se.com/il/he/work/support/customer-care/contact-support.jsp
mike_meirovitz
Commander
Posted: ‎2022-03-31 02:27 AM
Hi Craig,
Thanks. We are SE Technology partners. I assume we can open a case. Can you send me a link for this PSS system so I can try log in?
Thanks.
Mike
mike_meirovitz
Commander
Posted: ‎2022-06-20 11:31 AM
3730
Hi Armend,
The customer sent us the WireShark log while starting the SmartConnector Discovery processor. See attached.
Can you please have a look? Maybe you can see what is causing the processor to fail getting the alarms?
 Thank you.
Mike
wireshark_capture-_202204214_0923 (1).pcapng
ardak
Posted: ‎2022-06-20 11:58 PM
3718
I have taken a look and this seems to be an issue in EBO. The request from Smartconnector looks fine.
I recommend you to contact EBO support so they can take a look.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2022-06-21 02:08 AM
3713
Hi Armend,
Thank you for your answer. Can you please explain the EBO issue? We need to explain what is the exact EBO issue.
We are not authorized to create an EBO case.
Can you please elaborate?
Thank you.
Mike
ardak
Posted: ‎2022-06-21 02:11 AM
You can contact support through the link @CraigEl supplied a couple of answers above this:
