SmartConnector codes and types
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector codes and types
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
esari
esari Schneider Alumni (Retired)
Posted: ‎2021-05-04 05:18 AM
2566
Hello
Is there list of SmartConnector ID codes and types?
I have noticed that 00 type 0 is folder and 01 type 3 is analog point and 03 type 3 is trend logs. Where can I find all the codes and types?
Code is in smartconnector ID before sbo path.
Esa
JeffBowman
Sisko
Posted: ‎2021-05-07 08:00 AM
Hi Esa,
There is no list that I am aware of that actually maps all of EBO object types to these codes.
Best Regards,
-Jeff
Replies 4
RyanSuar
Admiral RyanSuar Admiral
Admiral
Posted: ‎2021-05-04 05:59 AM . Last Modified: ‎2022-10-19 01:43 AM
2563
Is this what you are after? I took it off this https://community.se.com/t5/SmartConnector-Forum/Is-there-a-definitive-list-for-the-numbers-at-the-b....
00 = Container Item
10 = A Value item that is a property of a Container Item
20 = Alarm Item that is a property of a Container Item
30 = History item that is a property of a Container Item
01 = Value Item
11 = Value Item that is a Property of another Value item (e.g. the priority array elements of a BACnet point)
21 = Alarm Item that is a property of a Value Item
31 = History Item that is a property of a Value Item
02 = Alarm Item
12 = Value Item that is a property of an Alarm Item
22 = Alarm item that is a property of another Alarm item
32 = History Item that is a property of an Alarm item
03 = History Item
13 = Value Item that is a property of an History Item
23 = Alarm item that is a property of a History item
33 = History Item that is a property of an another History item
esari
Posted: ‎2021-05-04 10:16 PM
2558
Hello
Yes, those are codes or numbers. Do you have also types included some list? 01 'Value item' is not explainin enought for third party programmer so I need to add also type. I found that
For 01 types are
1 binary
2 string
3 analog value
4 multistate
5 timestamp
Is there full list of numbers with types and descriptions ?
Esa
RyanSuar
Admiral
Posted: ‎2021-05-07 01:07 AM
Hi Esa, the list is what I could find. Perhaps someone else might have more info on this.
JeffBowman
Sisko
Hi Esa,
Best Regards,
-Jeff
