SmartConnector Success Kit
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector Success Kit
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Smart Connector
Smart Connector - Microsoft SQL Database Integration
EcoStruxure™ Building Operation
Back to SmartConnector Forum
Daniel_Cerone
Lieutenant JG Daniel_Cerone Lieutenant JG
Lieutenant JG
Posted: ‎2023-07-25 05:29 AM . Last Modified: ‎2023-12-11 01:00 PM
6
6998
All,
I have created a comprehensive SmartConnector success kit for use at the sales stage, execution stage, and maintenance stage of SmartConnector projects.
It includes:
  1. What is a SmartConnector and when to use it?
  2. Common architectures.
  3. Project Management and technical team considerations.
  4. "Gotchas" to watch out for.
  5. Sample task list for project execution.
  6. Detailed install steps.
  7. Using Swagger and Postman for API calls.
  8. Support resources.
This kit is the culmination of real-world project experience, from start to finish.  I hope it helps!
THIS KIT PROVIDED WITHOUT WARRANTY OR GUARANTEE OF RESULTS.  THE AUTHOR IS NOT RESPONSIBLE FOR THIS KITS CONTENTS AND THEY ARE NOT REGUALRY UPDATED.  REFER TO THE OFFICIAL SMARTCONNECTOR MANUALS FOR THE LATEST INFORMATION.  FOR SYSTEM ARCHITECT SUPPORT, CONTACT YOUR TSM OR CREATE AN OPPORTUNITY REQUEST.
Updates:
-12/11/23: Added additional signed certificate steps to SmartConnector Guide.docx.
/dcer
  • Thumbnail of Smart Connector
    Smart Connector
  • Thumbnail of Smart Connector - Microsoft SQL Database Integration
  • Thumbnail of EcoStruxure™ Building Operation
View products (3)
Replies 6
RandyBrooks
Crewman RandyBrooks Crewman
Crewman
Posted: ‎2024-08-05 08:48 AM
Will Smart Connector work for sending trend information from an EBO server to a customer's SQL Database?
CraigEl
Administrator CraigEl Administrator
Posted: ‎2024-08-05 07:57 PM
@RandyBrooks there is already an External Log Storage option in EBO 5.0 and later that allows trends, alarms and events to be sent to MSSQL
osanchez_sieesa
Ensign osanchez_sieesa
Ensign
Posted: ‎2024-08-28 04:31 PM
4750
Hello @Daniel_Cerone, in the guide you made is mentioned that SQL and SmartConnector are to be installed on the same server; whether that is a dedicated SmartConnector server or an ES.
If that is not possible for client policies, is there a way to work with a new empy SQL Database in a Shared Instance on a remote server?
They gave me this information for the deployment:
SQL Instance: instance@example.example.example.com
Database Name: SmartConnector
Database User: ebo
Privilege: db_owner
davepetteys_tbs
Lieutenant | EcoXpert Master davepetteys_tbs Lieutenant | EcoXpert Master
Posted: ‎2025-03-17 07:51 AM
3755
The 'SmartConnector Installation and Configuration Guide - EcoStruxure Building Operation'  states (on the last page) that the latest supported Windows Server OS is Server 2019. Is this up to date (as Enterprise Server already supports Server 2022)?
Daniel_Cerone
Lieutenant JG
Posted: ‎2025-06-19 06:00 AM
You can install it on a separate server but if the connection drops between EBO and the remote server, you risk the SmartConnector service stopping which causes the integration to fail.  You could try to rectify this using a script, batch file, or auto restart on the service, but it's a bit tricky.  You should test this.
/dcer
Daniel_Cerone
Lieutenant JG
Posted: ‎2025-06-19 06:01 AM
I think the SmartConnector official guide says 2016 but I've used 2022 Server and the latest MS SQL- seemed fine with most integration applications.  Would verify this with a test should you use newer (and for security purposes/featureset, you should).
/dcer
