Looking for software to program MSC-MSP-001 controller
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Looking for software to program MSC-MSP-001 controller
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
KJT
KJT
Cadet
Posted: ‎2025-07-16 02:00 PM
I have a MSC-MPC-001 controlling my residential hydronic boiler system. After a 45 minute power outage, the boiler would not fire when a thermostat asked for heat, specifically the hot water tank. Had local heating and plumbing company come check it out. Result was that they couldn't figure out what was wrong. They put in a temp fix to link the hot water tank thermostat directly to the boiler to get us hot water. I need to get the software to load on a laptop so I can connect directly to the controller board (RS232) and see what it says. The controller and modules involved are:
MSC-MPC-001
MPC-4AO
MPC-8AI
MPC-4CO-CE
Also considering getting the MSC-HOI.
I have replaced the boiler relay connected to the controller with a known good one with no change. Planning on changing out the backup battery as it was last changed back in 2009 (before I purchased the house).
So, if someone would kindly point me to the appropriate software that works with my controller I would appreciate it.
Thank you in advance.
Replies 0
