HI All,
I facing issue SmartConnector Service Won’t Start After Install. Any idea?
I tested v2.2 and v2.4 also facing same issue.
I did installed the .NET 4.8
WIndow 10 pro.
Hi Jeffrey, make sure during the SmartConnector installation, Database Server Name and Database Name are correct. I had a similar problem and my issue was I did not set the correct Database Server Name.
Have you checked the log in c:\ProgramData\SmartConnector\Logs ?
This might give you the answer you are looking for..
BR,
Erwin
