SmartConnector Portal could not be retrieved
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector Portal could not be retrieved
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2017-04-25 07:39 AM
1089
What could be the reason for this error? This is on a customer site.
Initially I was able to access the Portal.
I browsed to https web version of an AS in chrome and installed the certificate, the portal is showing Access Denied error.
I deleted the certificates, but still see the same issue.
The processors are running in the background but I am unable to get to the portal.
Replies 4
sesa180908_brid
Commander
Posted: ‎2017-04-25 07:47 AM
1042
Accessibility to the portal has nothing at all to do with an AS.  It does however have everything to do with how the portal is configured.  Your screen shot indicates that the portal is configured on the loopback address.  So you'll only have access to it if you are physically on that box or RDP'ed into it.  Where exactly did you install a certificate?  If it's on the SmartConnector box, you'll need to change the address of the portal to use that.
sesa180961_brid
Lieutenant
Posted: ‎2017-04-25 11:49 AM
The SmartConnector service is on the same machine where I am using 127.0.0.1.
I installed the following certificate on the same machine. But I deleted them later assuming that they might have caused the issue.
sesa180961_brid
Lieutenant
Posted: ‎2017-04-26 09:52 AM
1042
Is there something I need to check on proxy settings or IIS or any certificate to install?
sesa180908_brid
Commander
Posted: ‎2017-05-02 07:04 AM
SmartConnector doesn't use IIS.
Please review section 12 of the SmartConnector Installation and Configuration Guide.pdf  for how to configure SmartConnector with certificates.
