IE requirement for Smartconnector Portal
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • IE requirement for Smartconnector Portal
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2017-04-21 11:19 AM
889
I installed Smartconnector on a customer site. They have IE8. Javascript/Active Scripting is enabled.
I am able to browse to the portal http://127.0.0.1:8082/Login but I have errors on the page.
Is there a requirement of later version if IE to use the portal?
Message: Object doesn't support this property or method
Line: 2
Char: 29759
Code: 0
URI: http://127.0.0.1:8082/js/jquery.min.js
Message: Bootstrap's JavaScript requires jQuery
Line: 6
Char: 31
Code: 0
URI: http://127.0.0.1:8082/js/bootstrap.min.js
  • portal
sesa180908_brid
Commander
Posted: ‎2017-04-21 11:30 AM
868
SmartConnector uses a somewhat older version of jQuery, it is one that certainly supports IE8.  Can supply the actual call stack of the JavaScript that is causing the error?
That said, IE8 is a pretty dated.  If possible, update to a newer version or say Chrome.
sesa180908_brid
Commander
869
sesa180961_brid
Lieutenant
Posted: ‎2017-04-21 11:41 AM
The call stack is empty but here is the console:
Yes, if IE8 does not work, requesting a browser update is the way I am going.
Thanks!
