SmartConnector Forum
When I click on the View Feed on smartconnectorserver.com (in My Profile), I get this message:
You are not allowed to access this feed.
Any idea why I am not allowed?
Mike
Hi Milou,
Not sure I understand... Where can I find the following:
Database>> User >> update your InvitedToMyGet to 1
Mike
Smartconnector server database >>> table>>> user
Do you have access to Smartconnector server database?
I can access SmartConnectorServer.com...
I don't see any Database menu... Can you send me a screenshot?
Mike
OK... I see. Yes, I have access to SQL server. See below. Which table?
Mike
Just curious… I don’t see any relationship between smartconnectorserver.com and a local database .. as far as i know there is no “online” connection between those two platforms.. i think something is getting mixed up here..
Sorry, I have mixed the concepts a bit.
There may be several reasons why a MyGet invite is not sent out, the user needs to register a tenant and register as a user on SmartConnector Server.
Are you registered correctly in SmartConector Server?
Hi Mike,
If you are registered correctly in the smartconector server, I need your email to invite you manually from MyGet.
br
Nilou
The email address I use to login to SmartConnectorServer.com is micham@controlsee.com.
Thank you.
Mike
Please test it and let me know if it works or not.
Nilou
I was able to download the NuGet packages zip file. Thank you.
Mike
I followed the Obtaining Smart Connector process in the Developer's Guide, and I authenticated with https://www.smartconnectorserver.com. I never received a response on "Send a request to become a SmartConnector Developer."
I also have a MyGet account, if that's needed. Can you help me get access to SmartConnector's MyGet packages? Thanks.
thanks
Please test and let me know if it works or not.
I can now se the feed in myget,
thank you for quick response 🙂
I never received a response too. Can I get invite link? Here my mail: nihat.demirbilek@7kr.com.tr
Thank you. It is working now.
I'm in the same boat, I need an invite. Jesus.Guillen@se.com
Done!
Please send a MyGet invitation to rhea.demelo@provecta.com.au and karina.romero@provecta.com.au
Hi
Can you send a MyGet invitation to me too? Thanks
shbu@uggerly.dk
I am reaching out regarding an issue with my developer application. I initially submitted the form to become a developer nearly three weeks ago. However, I was required to fill out the same form again recently, and I have yet to receive any confirmation or email regarding my application status.
Could you please assist me with this matter? My email address is kambiz.zakaria@bravida.no.
Thank you.
