Guidance Needed for Long-Running Alarm Processor
SmartConnector Forum
Send InviteCancel
2025-01-0601:41 AM
Hi All,
I’ve been researching online and noticed that the documentation might be a bit outdated for what we’re trying to achieve.
While digging, I came across this repository: SmartConnectorUtilities, where I also found Jeff’s email.
What we’re aiming to accomplish is a long-running (essentially indefinite) processor that can loop through alarms and send HTTP requests as they come in. Is this feasible?
If so, could we get some guidance on the best approach? I’ve been trying to query the alarms using the source code in the linked repository as well as using the built in REST API but I can't query in bulk for those alarms and it’s been challenging. Are there any additional resources or documentation that might help with this?
