Smart Connector - Get TrendSamples
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Smart Connector - Get TrendSamples
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
esari
esari Schneider Alumni (Retired)
Posted: ‎2022-03-22 05:32 AM . Last Modified: ‎2022-04-28 06:49 AM
1212
Hello
I noticed that if Smart Connector user tries to get data from COV trend log which has no new data for couple of months then response will be empty. If user will use sampleOnOrAfter parameter with value "2021-12-01" then response will show COV trend.
What is oldest date which Get TrendSamples will return when using only trendid parameter?
We had some boolean values which have not changes very often, but customer would like get that data even it has not been changed for couple of months.
Esa
ardak
Posted: ‎2022-03-22 06:36 AM
Hi Esa,
The default value for sampleOnOrAfter is 30 days.
I will make sure it's added to the docs for the next version.
BR
Armend
ardak
Hi Esa,
BR
Armend
