SmarConnectorWeather Update Problems
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmarConnectorWeather Update Problems
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2021-10-07 12:54 AM . Last Modified: ‎2021-10-07 12:55 AM
1296
I  have done all the settings and licensing but I can't see the current values ​​what could be the problem
Replies 4
Erwin-vd-Zwart
Janeway
Posted: ‎2021-10-07 01:08 AM
1292
Could be a lot of reasons, what i usualy do is run the extention in VB Test Explorer (debug) and add breakpoints in the code, first i check the response of the API where i fetch the data to see if i even get values returned from there, could be your API key is not valid or any other error, when i see the received dataset is valid i continue with breakpoints to check where it might go wrong..
When the debug is passing the tests then i proceed to add the extention to the framework...
Posted: ‎2021-10-07 02:06 AM
1288
Erwin-vd-Zwart
Janeway
Posted: ‎2021-10-07 02:18 AM
1
1286
No, but i have no clue what you are trying to do, your URL is pointed to a SOAP endpoint at your localhost but i asume your weather service is not on your localhost and neither a SOAP endpoint.. (should be REST as far as i know)
Normally you have the wsdl when having a EWS but that would be localhost:portnr/EcoStruxure/DataExchange?singleWsdl
As suggested before, first run the extention in Visual Studio Test Explorer, debug it, make sure your endpoint is reachable and returning the weather data and then deploy it to the framework..
Posted: ‎2021-10-08 05:40 AM
i have runned the extention in Visual Studio Test Explorer and add breakpoint and deploy , i have started to see current values from SC Portal, and for make a SOAP web service call to our EWS endpoint with SoapUI , i have used as WSDL location  http://localhost:5300/SmartConnectorWeatherService?singleWSDL i get  error <java.lang.Exception: Failed to load url >
