What license is the SmartConnector Weather Extension demo asking for?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • What license is the SmartConnector Weather Extension demo asking for?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2021-10-05 05:17 AM
1763
111.PNGI have been following the Developer's guide to create the demo weather extension. I have added the extension to the SmartConnector portal and now when it comes time to validate my processor I get the error "No license found". I noticed that when running the test scripts on visual study with Debug on the tests pass, but when I switch to Release I also get the No license found error message. Can someone help me figure out what license I need and where I can get it? I was under the assumption that this demo did not require any type of licensing.
Replies 8
ardak
Posted: ‎2021-10-05 05:33 AM
1756
All the information you need on licensing is in the developers guide.
If you have copied the code from the SmartconnectorSamples repo your "error" is probably in WeatherProcessorBase
#if DEBUG
        public override bool IsLicensed => false;
#endif
        // Either uncomment or add the license file from GitHub to your local SmartConnector runtime.
        //#region IsLicensed - Override
        //public override bool IsLicensed => false;
        //#endregion
If you want the processor to be unlicensed in release builds you need to remove the #if and #endif.
Posted: ‎2021-10-05 11:47 PM
1749
i have added the license from GitHub to the SmartConnector portal  but  i am  still see the "No license found" line
ardak
Posted: ‎2021-10-06 12:10 AM
1746
Again, all the info you need is in the developers guide document under licensing. Furthermore, I've provided two different ways you can move forward, and you choose a third way that does not work. I can't help you that way.
BR
Armend
Erwin-vd-Zwart
Janeway
Posted: ‎2021-10-06 12:30 AM
1743
In your case for testing you should disable the license in your code as Armend suggested, but if you realy want to add a license to your assembly please watch this video: https://www.youtube.com/watch?v=8FfPdVwgn00&feature=emb_logo
Posted: ‎2021-10-06 12:42 AM
1741
i have delete   the override end rebuild but i can not find  .lic file on SmartConnectorWeatherExtension>bin>debug
Erwin-vd-Zwart
Janeway
Posted: ‎2021-10-06 12:48 AM
Just make sure your code is like this, then you don't need a license..
#endregion
Posted: ‎2021-10-06 05:23 AM . Last Modified: ‎2021-10-06 05:56 AM
1730
I have done  asonnnn.jpgll the steps in the video but I still get the error 222.PNG
Erwin-vd-Zwart
Janeway
Posted: ‎2021-10-06 06:58 AM . Last Modified: ‎2021-10-06 07:05 AM
Did you copied the public key from the portal back into your AssemblyInfo.cs as explained in the video (somewhere around 10:00 to 10:20), compiled a new .dll and copied the new .dll to the SC installation folder?
But for my understanding, why don't you just disable the license to get this demo up and running, what is the purpose of embedding the license feature in this trial demo?
