Question Regarding Lonworks Linking Mirrored Network Variables from Controllers to the Local Node
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Question Regarding Lonworks Linking Mirrored Network Variables from Controllers to the Local Node
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
ace.bernabe
Crewman ace.bernabe
Crewman
Posted: ‎2024-09-04 02:40 AM . Last Modified: ‎2025-10-10 02:56 AM
Hi All,
I'm working on a project with Lonworks controllers and am trying to create network variables in the local node by mirroring network variables in the LonWorks field bus devices. I'm doing this based on the Creating and Configuring a LonWorks Network with MNL LonWorks Devices [102423].pdf document which I've also attached for reference.
I'm using EcoStruxure Building Operation Software 5.0, but I've encountered an error: The Workstation gets stuck on this loading popup that says, "Another operation is in progress. Your operation has been queued."
I've attached a picture of the issue for reference. It gets stuck here and the mirrored network variables are never created. At this point, I usually need to close Workstation since it keeps loading forever.
I would appreciate any help at all regarding this matter thanks.
Replies 0
