Force Modbus Digital Output or Analgo Output Point Value
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Force Modbus Digital Output or Analgo Output Point Value
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
felipe.takara
Crewman felipe.takara
Crewman
Posted: ‎2024-08-22 06:35 AM
688
Is there any configuration in EBO so that I can force the modbus point value?
I need to give a command to a pump and I can't force the digital output point to be true
Dgmeinsider
Dgmeinsider
Cadet
Posted: ‎2024-09-01 12:56 PM
In EBO (EcoStruxure Building Operation), you can force a Modbus digital or analog output point value by creating a control script or using a control strategy that overrides the current value. While EBO doesn’t directly support forcing values in a straightforward manner, you can achieve this by scripting the desired output values. For digital outputs, you can set the output to true or false, and for analog outputs, you can script the output to the desired value. Ensure your Modbus mapping and communication settings are correct and check for any conflicting commands that might override your settings.
