ProcessorValues not being refreshed in Long Running process
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • ProcessorValues not being refreshed in Long Running process
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2018-05-02 03:06 AM
1250
I have a long running processor that relies upon the values in ProcessorValues. I also have a custom setValueProcessor that updates these PV values. Every 5 seconds the processor asks for the current values, this has been updated by the setValueProcessor but the copy of the PV values my processor gets is from when the process started.
How can I force the method below to get the database instance of PV values rather than a cached instance?
protected ProcessorValue FindOrCreateProcessorValue(string key, string group = null, string aggregate = null)
            var pv = this.ProcessorValueSource.Items.FirstOrDefault(x => x.Key == key && (group == null || x.Group == group) && (aggregate == null || x.Aggregate == aggregate));
            if (pv == null)
                pv = new ProcessorValue
                    Key = key,
                    Group = group,
                    Aggregate = aggregate,
                ProcessorValueSource.Add(pv);
                ProcessorValueSource.Save();
            return pv;
sesa180908_brid
Commander
Posted: ‎2018-05-02 06:25 AM
You don't need to call the object factory.Simply calling DisposeOfProcessorValueDataSource() from your Processor is sufficient.
ProcessorValueSource is lazy loaded when it is next needed.
JeffBowman
Sisko
Posted: ‎2018-05-02 06:18 AM
1222
Hi James!
Good question, I took a look at the source, and it looks as though you should be able to refresh your processor values source by setting it to a new instance of IProcessorValueDataSource. Try the below:
this.ProcessorValueSource = MongooseObjectFactory.Current.GetInstance<IProcessorValueDataSource>();
-Jeff
sesa180908_brid
Commander
