One License file for Multiple Assemblies
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • One License file for Multiple Assemblies
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa237670_brid
sesa237670_brid Schneider Alumni (Retired)
Posted: ‎2018-05-02 05:09 AM
1830
I am wondering if it is possible to assign one License file to two assemblies. Our solution has one SmartConnector Extension assembly and another Endpoints Configuration extension. I can create two separate License for them but we want to assign one license to both assemblies to make it simple for the customer. Let me know if it is possible? I tried and see that License template can only be assigned to one assembly even if I try to use same assembly Id for them.
Thanks!
Neeraj Tomar
JeffBowman
Sisko
Posted: ‎2018-05-02 06:01 AM
1797
Hi Neeraj,
As far as I know, this is not possible today (Mark Stemmler​ can you confirm?). Your best bet would be to merge the code into the same project (copy the class ), doing it this way would make it even easier as the user only need to copy 1 file and not keep track of multiple as well when deploying/ updating.
-Jeff
JeffBowman
Sisko
1798
Hi Neeraj,
-Jeff
sesa180908_brid
Commander
Posted: ‎2018-05-02 06:03 AM
1
1797
Correct, Extension licensing is on "per assembly" basis.
sesa237670_brid
Posted: ‎2018-05-02 10:19 AM
Ok ! I thought so. Thanks!
